Keyboard shortcuts
This topic gives an overview of keyboard shortcuts that can be used in the Designer.
Although some of the keyboard shortcuts are the same, this isn't a complete list of Windows keyboard shortcuts. To find that, refer to the documentation of the Windows version that you are using.
Menu items
The following key combinations activate a function in the menu.
Alt
Put the focus on the menu. (Alt + the underlined letter in a menu name displays the corresponding menu.) The menu can then be browsed using the Enter key, arrow up and arrow down buttons.
Alt + F4
Exit
Alt + Shift + D
Design view
Alt + Shift + E
Preview HTML
Alt + Shift +L
Live view
Alt + Shift + P
Preview view
Alt + Shift + S
Source view
Ctrl + C or: Ctrl + Insert |
Copy
Ctrl + F
Find
Ctrl + I
Properties
Ctrl + N
New
| Ctrl + O |
Open file |
| Ctrl + P |
Print |
Ctrl + R
Show/hide rulers
Ctrl + S
Save file
Ctrl + V or: Shift + Insert |
Paste
Ctrl + X or: Shift + Delete |
Cut
Ctrl + W
Close file
Ctrl + Y or: Ctrl + Shift + Z |
Redo
Ctrl + Z
Undo
Ctrl + Alt + ;
Lock guides
Ctrl + Shif + R
Clear preview cache
Ctrl + Shift + S
Save all
Ctrl + Shift + W
Close all
Ctrl + Shift + ;
Snap to guides
Ctrl + ;
Show guides
Ctrl + '
Show/hide virtual stationery
Ctrl + \
Highlight items
Ctrl + F5
Revert
Ctrl + F10
Save as
Ctrl + F11
Send COTG test
Ctrl + F12
Send to Workflow
/ Package files |
Workspace
The following key combinations activate a function in the Workspace.
Alt + - |
Open system menu
Alt + F7 or: Alt + Page Down
Next tab
Alt + Shift + F7 or: Alt + Page Up
Previous tab
Ctrl + A
Select all
Ctrl + Shift + E
Switch to Editor
| Ctrl + F |
Find (opens the Find and Replace dialog: Find/Replace Dialog) |
Ctrl + F6
Next editor (when there is more than one file open in the Workspace)
Ctrl + Shift + F6
Previous editor (when there is more than one file open in the Workspace)
Shift + F10 or: Ctrl + Shift + F10
Open menu
Design and Preview tab
In addition to the keyboard shortcuts for menu items and the Workspace, the following key combinations have a special function in the Design tab and Preview tab of the Workspace.
Ctrl + B
Bold (works on a text selection)
Ctrl + E
Open Paragraph formatting dialog
Ctrl + I
Italic (works on a text selection)
Ctrl + H
Show Edges
Ctrl + K
Delete browser element
| Ctrl + M |
Open Box formatting dialog |
| Ctrl + T |
Open Text formatting dialog |
Ctrl + U
Underline ( (works on a text selection)
Ctrl + + or: Ctrl + Shift + + or: Ctrl + = or: Ctrl + Shift + = |
Zoom in |
Ctrl + - or: Ctrl + Shift + - |
Zoom out |
Ctrl + 0
Zoom to page width
Ctrl + 1
Zoom to page content width
Ctrl + arrow up
Select parent
Ctrl + Shift + R or: F5
Refresh |
Text editors: Source tab, JavaScript, CSS, Script Editor
The following key combinations have a special function in the Source tab of the Workspace (see also: Source Tab), and when editing a JavaScript or CSS file in the Workspace, and in the Script Editor (expanded view).
Ctrl + space
Content assist (auto-complete)
Ctrl + A
Select all
| Ctrl + D |
Duplicate line |
| Ctrl + F |
Find |
Ctrl + I
Indent (Tab)
Ctrl + J (not in Script Editor) |
Incremental find; start typing a search string directly after pressing this key combination.
(Not in the Script Editor.) |
Ctrl + K
Find next
Ctrl + L
Go to line; a prompt opens to enter a line number.
| Ctrl + Shift + D |
Delete line |
Tab
Expand Emmet abbreviation (see Emmet Preferences)
Shift + Tab
Shift selected lines left
Tab
Shift selected lines right
Script Editor
There are a few different key combinations in the Script Editor (expanded view).
Ctrl + J
Line break
Ctrl + Q
Comment/uncomment; this adds or deletes // before the line.
Scripts pane and Resources pane
The following keys or key combinations have a special function when a file is selected in the Resources pane and when a script is selected in the Scripts pane.
F2
Rename
| Alt + Enter |
Open Properties dialog |
| Delete |
Delete |
Data Model pane
You can use the following keys to browse records in the Data Model pane:
- Page Up: next record
- Page Down: previous record
- Home: first record
- End: last record.
