Codabar Settings
Codabar barcodes support the following data: 0-9 - $ : / . + plus the optional specification of start/stop characters.
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
  • Position group:
    • Output once per sheet: Option relates to Imposition (also known as N-Up) printing. Select this box to have the Barcode printed once per sheet rather than once per document page.
      If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
  • Codabar Properties group:
    • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
    • Module Width: Specifies the width of the narrow bars. Changing this value to higher value will generally make the Barcode bigger.
    • Bar width ratio: Set the Barcode bar width.
    • Default start symbol: Use the drop-down to select the optional Barcode start character, which defines the encoding mode.
    • Default stop symbol: Use the drop-down to select the Barcode stop character, which defines the encoding mode.
    • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
      • Display start/stop symbols check box: Adds the stop/start symbols to the Barcode text.
      This includes metadata fields which must previously have been added in the Metadata Options (likely at the Document Tags level), as well as some information fields.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
  • Last Topic Update: 05, July, 2017 02:10 AM
  • Last Published: 2019-05-23 : 3:20 PM
