Code 39 Settings
Code 39 is a discrete, self-checking barcode that is also known as "Alpha39", "Code 3 of 9" (often abbreviated to "3 of 9"), "Code 3/9", "Type 39", "USS Code 39" and "USD-3".
Code 39 data should contain no more than 20 digits from within the following range: Numeric digits: (0-9), upper-case letters (A-Z), seven special characters (- . space $ / + %) and the start/stop asterisk (*) character.
If the Extended character set is chosen, then lower-case letters (a-z) and other special ASCII characters can also be included.
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode. Use the following options to configure the output Barcode settings:
- Code 39 Properties group:
- Height: Enter the Barcode
height in either metric (cm/mm), inch (in) or point (pt) values.
- Use extended character set:
Check to use the Code 39 Extended character set. This extends the range of supported data to include the full ASCII character set. This adds support for lower case letters (a-z) and the full range of ASCII punctuation and special characters.
- Module Width: Specifies
the width of the narrow bars. Changing this value to
higher value will generally make the Barcode bigger. The smallest Module Width is 0.19mm (high density).
- Bar width ratio: Set the Barcode bar width.
- Checksum: Use the drop-down
to select how to deal with the Barcode checksum:
- Ignore: Ignore checksum calculations.
- Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
- Check: Verify the Barcode has a valid checksum.
- Add: Calculate and add a checksum character to Barcode, regardless of current value.
- Print human readable text:
Check to add a textual version of the Barcode data.
- Placement: Use the
drop-down to select whether to place the human readable text above
or below the Barcode.
- Font name: Use the
drop-down to select the font with which to display the human readable
text.
- Font size: Enter a
font size for the human readable text.
- Text: Enter the text used
to generate the Barcode.
Add button: Click to display
a list of variable data that could be used for generating the Barcode. This
includes metadata fields which must previously have been added in the Metadata
Options (likely at the Document Tags level), as well as some information fields.
- Condition: Enter the condition
which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
a list of metadata fields, information fields to add, or common
expressions to the condition.
