Data Matrix Settings
A Data Matrix barcode is a high-density, two-dimensional (2D) matrix barcode which supports encoded text, numbers, files and digital data.
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode. Use the following options to configure the output Barcode settings:
- Datamatrix Properties g:
- Module Width: Specifies
the width of the narrow bars. Changing this value to
higher value will generally make the Barcode bigger.
- Encoding: The data represented
in the symbol can be compressed using one of the following algorithms:
- Auto: Automatically
detect the data content and encodes using the most appropriate
method. This is the default option.
- ASCII: is used to encode
data that mainly contains ASCII alphanumeric characters (ASCII 0-127). Use where Barcode size is a concern and where the data is alphanumeric.
- Base 256: used to encode
8-bit values.
- C40: used
for data that mainly consists of numbers and upper-case alphabetic letters.
- Text: used
for data that mainly consists of numbers and lower-case alphabetic letters.
- None: Does not
use any encoding.
- Format: select the Barcode size format from the drop-down list .
- Text: Enter the text used
to generate the Barcode.
Add button: Click to display
a list of variable data that could be used for generating the Barcode. This
includes metadata fields which must previously have been added in the Metadata
Options (likely at the Document Tags level), as well as some information fields.
- Condition: Enter the condition
which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
a list of metadata fields, information fields to add, or common
expressions to the condition.
