PDF417 Settings
PDF417 is a two-dimensional, multi-row Barcode. It is used for encoding large amounts of data, with hundreds or even thousands of characters. It encodes alphabetic text, numbers, binary files and actual data bytes.
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
  • Position group:
    • Output once per sheet: Option relates to Imposition (also known as N-Up) printing. Select this box to have the Barcode printed once per sheet rather than once per document page.
      If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
  • PDF417 Properties group:
    • Module Width: Specifies the width of the narrow bars. Changing this value to higher value will generally make the Barcode bigger.
    • Row height: Defines the height of the bars for a single row, measured in pixels, points or metric.
    • Width to height ratio: Select the ratio of column width to row height.
    • Mode: Use the drop-down to set the compaction mode.
      • Binary: allows any byte value to be encoded.
      • Text: allows all printable ASCII characters to be end coded (ASCII values 32 to 126 and some additional control characters).
      • Numeric: more efficient mode for encoding numeric data.
      • Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
    • Error Correction Level: Enter the error correction level for the built-in error correction method based on Reed-Solomon algorithms. The error correction level is adjustable between level 0 (just error detection, without correction) and level 8 (maximum error correction). Recommended error correction levels are between level 2 and 5, but the optimal value depends on the amount of data, printing quality of the PDF417 symbol and decoding capabilities.
    • Rows: A PDF417 bar code can have anywhere from 3 to 90 rows.
    • Columns: The number of data columns can vary from 1 to 30.
      This includes metadata fields which must previously have been added in the Metadata Options (likely at the Document Tags level), as well as some information fields.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
  • Last Topic Update: 05, July, 2017 02:10 AM
  • Last Published: 2019-05-23 : 3:20 PM
