Royal Mail 2D Settings
Royal Mail 2D Mailmark Barcodes are a variant of 2 Dimensional Datamatrix barcodes. They are used by the British Royal Mail postal service. They contain the address of the receiver, encoded in alpha-numeric format (0-9, A-Z).
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode. Use the following options to configure the output Barcode settings:
- Royal Mail 2D Properties group:
- Text: Enter the text used
to generate the Barcode.
Add button: Click to display
a list of variable data that could be used for generating the Barcode. This
includes metadata fields which must previously have been added in the Metadata
Options (likely at the Document Tags level), as well as some information fields.
- Condition: Enter the condition
which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
a list of metadata fields, information fields to add, or common
expressions to the condition.
