Royal Mail Settings
Royal Mail Barcodes (also known as RM4SCC, RoyalMail4SCC and Royal Mail 4-State Customer Code), are used by the British Royal Mail postal service. They contain the address of the receiver, encoded in alpha-numeric format (0-9, A-Z).
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
  • Position group:
    • Output once per sheet: Option relates to Imposition (also known as N-Up) printing. Select this box to have the Barcode printed once per sheet rather than once per document page.
      If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
  • Royal Mail Properties group:
    • Track height: The height of the small vertical centre bars, in metric (mm/cm). Value must be between 1.02 mm and 1.52 mm.
    • Full bar height: Height of the tallest vertical bars, in metric (mm/cm). Value must be between 4.22 mm and 5.84 mm.
      The ascender and descender bar heights are automatically calculated based upon the Full and Track bar heights.
    • Module width: Thickness of each bar in the Barcode, in metric (mm/cm). Value must be between 0.38 mm and 0.63 mm.
    • Module spacing: The spacing between each bar, in metric (mm/cm). Value must be between 0.38 mm and 0.63 mm
      This includes metadata fields which must previously have been added in the Metadata Options (likely at the Document Tags level), as well as some information fields.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
  • Last Topic Update: 04, June, 2018 10:15 PM
  • Last Published: 2019-05-23 : 3:20 PM
