US Postal Service IMB Settings
US Postal Service Intelligent Mail Barcodes (IMB) are used by the United States postal service. They contain the address of the receiver, encoded in numeric format (0-9).
To create dynamic barcodes, Metadata Options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
  • Position group:
    • Output once per sheet: Option relates to Imposition (also known as N-Up) printing. Select this box to have the Barcode printed once per sheet rather than once per document page.
      If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
  • USPS IMB Properties group:
    • Track height: The height of the small vertical centre tracking bars, in inches (in). Value must be between 0.039 and 0.057 inches.
    • Ascender height: The height of the ascender bar.
      This also determines the height of the descender bar and full height bars, in inches (in). Value must be between 0.082 and 0.111 inches.
    • Module width: Thickness of each bar in the Barcode, in inches (in). Value must be between 0.015 and 0.025 inches.
    • Interchar gap size: The gap between the bars, calculated as a ratio of the module width, where a value of 1.0 equates to a gap width the same as the module width.
      Value must be between 0.012 and 0.04 inches.
    • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
      This includes metadata fields which must previously have been added in the Metadata Options (likely at the Document Tags level), as well as some information fields.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
  • Last Topic Update: 04, June, 2018 10:15 PM
  • Last Published: 2019-05-23 : 3:20 PM
