Printer Settings
The Printer Settings page defines options on the printer. It is available for PostScript (and the VIPP and VPS variants of PostScript) only.
  • Map media by options: Select from following choices:
    • Media Attribute displays all Media details, except the Tray selection.
    • Tray displays just the Media name and Tray selections.
    • Both displays all Media details.
  • Tray selection columns:
    • Media: Lists the Media name, as defined in the template.
    • Tray: Use the drop-down to select in which tray to send any page using the media.
    • Position: Enter a MediaPosition option on the printer to define the media to use.
    • Weight: Enter a weight for the paper.
    • Type: Use the drop-down to select which type of stock to use on the printer.
    • Color: Use the drop-down to select which color the paper should be on the printer.
  • Last Topic Update: 19, August, 2016 02:30 AM
