Print Using Advanced Printer Wizard
The Advanced Printer Wizard allows you to select from any and all output settings.
The Wizard can be used to generate once-off print runs (either entirely from scratch, or based upon selected pre-existing Presets).
Note: These print runs cannot be saved as presets and can only be replicated in the following print run, using the Last Used option.
The output settings are determined by selections made throughout the Wizard. For example, if you want to add Inserter Marks to the output, you select the Add Inserter Marks option on the first page of the Wizard, and the Inserter Options page will then appear later in the Wizard.
The first page of the Advanced Printer Wizard is the Print Options page.
  • Last Topic Update: 04, June, 2018 10:15 PM
  • Last Published: 2019-05-23 : 3:20 PM
