Finishing Options
Use this dialog to force specific finishing options, instead of using finishing options that were set in the Template's Media and Section options.
This is only applied when producing print output. It does not modify the original finishing options in either the Section or the Template.
  • Ignore section level finishing: Check to override finishing options at the document level only.
  • Section to edit: Use the drop-down to select which Section to apply the options below.
    The Document level is also listed to edit document-level finishing.
    • Settings: Click the settings button to bring up control options:
      • Reload: Restores the current Section's properties to the default values set in the template for this Section
      • Reload All: Restores all Section properties to the default values set in the template for each Section.
      • Apply finishing from: Displays a list of available Sections. Clicking on a Section name loads that Section's properties into the current Section to edit.
      • Apply current finishing to all sections: Applies the current properties to all Sections.
  • Binding group:
    • Style: What type of Binding to request on the printer. This includes Stapled, Glued, Stitched, Ring, and various other options..
    • Side: Sets the side of the paper that the Binding is to occur.
    • Location: Sets where the binding is to occur, if applicable.
      The selections available here are dependent upon the selection made in the Binding Style. Only Stapled and Stitched bindings have a Location option available to them.
    • Angle: Set Stapling or Stitching binding either horizontally, vertically, or at an angle (as supported by printer).
    • Item count: Select the amount of Staples or Stitches to use. The choice is between the default amount or selecting a specific number using the Count option.
      The options actually available to you at print time will be printer dependent, so you will need to know the capabilities of your printer, or leave the value set to Default.
    • Area: The area where the binding can be applied.
  • Hole making group:
    Hole making options are available only to Ring, Comb (wire and plastic) and Coil Binding Styles. The selections will need to be made at run-time based upon the types of binding options available that the printer supports.
    • Number of holes: The number of holes to punch for the selected Binding option.
    • StyleThe style of hole punches for the selected Binding option.
    • Pattern Catalog ID: The Catalog ID of the selected Binding option.
  • Load button: Click to select a previously created Output Creation Preset. This will change the Advanced Print Options to match the entries contained within the Preset.
  • Preview button: Click to launch a Proof Preview window, which displays how the printed output would look based upon the currently chosen selections.
  • Back and Next buttons: Used to navigate back and forth through all the selected options within the Wizard. Up until the Print button is pressed, one can reverse all the way through the wizard to return to the main selection page (the Print Options page) and add or remove printing options from the print run.
  • Print button: Click to produce print output according to the current settings. This can be done at any point within the Wizard, whether or not the options selected in the the Print Options page have been completed or not.
  • Cancel button: Cancels the Print Wizard, without creating any printout.
  • Last Topic Update: 31, July, 2017 03:16 AM
