Separation Options
This page defines how to separate the jobs using subsets, slip sheets, or jogging.
  • Sheet Count Splitting group.
    This group allows for the splitting of output based upon a pre-determined number of pages
    • Split: Use the drop-down to select how to split.
      • None: Select to ignore sheet count splitting entirely.
      • At exactly: Select to create a split at a specific sheet number.
    • Every: Enter the number of sheets at which to split the output.
  • Separation Settings group.
    This setting is only available if no Sheet Count Split were specified.
    • Separation: Use the drop-down to select when a job separation occurs, which is either None (no separation) or at the Job, Job Segment, Document or Document Set level.
  • Slip Sheets group
    • Add slip sheet: Use the drop-down to select whether to add a slip sheet before or after a specific separation, or whether to use none.
    • Every: Use the drop-down to select at which separation to add a slip sheet, at the Job, Job Segment, Document or Document Set level.
    • Media Size: Use the drop-down to select the media size of the slip sheet.
      If a custom Media Size was chosen:
      • Width: enter slip sheet page width.
      • Height: enter slip sheet page height.
  • Jog group
    • Jog after every: Use the drop-down to select when to jog the printer, which is either None (no forced jogging) or at the Job, Job Segment, Document or Document Set level.
  • Load button: Click to select a previously created Output Creation Preset. This will change the Advanced Print Options to match the entries contained within the Preset.
  • Preview button: Click to launch a Proof Preview window, which displays how the printed output would look based upon the currently chosen selections.
  • Back and Next buttons: Used to navigate back and forth through all the selected options within the Wizard. Up until the Print button is pressed, one can reverse all the way through the wizard to return to the main selection page (the Print Options page) and add or remove printing options from the print run.
  • Print button: Click to produce print output according to the current settings. This can be done at any point within the Wizard, whether or not the options selected in the the Print Options page have been completed or not.
  • Cancel button: Cancels the Print Wizard, without creating any printout.
  • Last Topic Update: 19, August, 2016 02:30 AM
  • Last Published: 2019-05-23 : 3:20 PM
