Control Script: Page numbering
This topic explains how to write a Control Script that changes the page numbering in Print sections. Note that when you add a Control Script, it already contains a script to make the page numbering continue over all Print sections.
How to change page numbering in a control script
A Control Script can make the page numbering continue over all Print sections or let it restart on a section. This is done by setting the restartPageNumber field on a section to true or false.
For example: merge.template.contexts.PRINT.sections['Section 2'].restartPageNumber = true;. (Also see section and Control Script API.)
Page numbering starts with page 1 for each section. If for a section restartPageNumber is set to false, that section will start with the page number following the last page of the previous section.
Note that even if a section is not enabled (so it will not be outputted), its restartPageNumber flag is still taken into account for composing the page number sequences.
By default, each section has restartPageNumber = false when the first control script runs.
If you are looking to create a table of contents, add a template script that uses the pageRef() function. For an example, see pageRef().
Examples
Restarting the page numbers several times
Assume that a template has four sections (of 1 page each) in the Print context and a Control Script sets the page numbering as follows:
  1. Section A (1 page) restartPageNumber = true
  2. Section B (1 page) restartPageNumber = true
  3. Section C (1 page) restartPageNumber = false
  4. Section D (1 page) restartPageNumber = true
The code would look like this:
if (merge.context.type == ContextType.PRINT) {
merge.context.sections['Section A'].restartPageNumber = true;
merge.context.sections['Section B'].restartPageNumber = true;
merge.context.sections['Section C'].restartPageNumber = false;
merge.context.sections['Section D'].restartPageNumber = true;
The page numbering in the output will be:
  1. Section A page 1
  2. Section B page 1
  3. Section C page 2
  4. Section D page 1
Disabled section
When a section is disabled, it will not be outputted, but its restartPageNumber flag will still be taken into account for composing the page number sequences. So, if the restartPageNumber flags are set as follows:
  2. Section B (2 pages) restartPageNumber = false
  3. Section C (3 pages) restartPageNumber = true, enabled = false
  4. Section D (4 pages) restartPageNumber = false
In code:
merge.context.sections['Section B'].restartPageNumber = false;
merge.context.sections['Section C'].restartPageNumber = true;
merge.context.sections['Section C'].enabled = false;
merge.context.sections['Section D'].restartPageNumber = false;
  1. Section A page 1
  2. Section B page 2
  3. Section D page 1 (page numbering is restarted due to section C's restartPageNumber = true)
  • Last Topic Update: 23, January, 2017 09:11 AM
