Control Script: Setting a Print section's backgroundIn the Print context, a PDF file can be used as a Print section's background. To learn how to do this without a Control Script, see Using a PDF file as background image. For information about Control Scripts in general, see Control Scripts and Control Script API. If you don't know how to write scripts, see Writing your own scripts. Setting a background in scriptThe Control Script should first enable a background on the section, in case an initial background wasn't set via the user interface. This is done by setting the source type for the background of the section to either DataMapper PDF or Resource PDF (see BackgroundResource). For example:
A DataMapper PDF is, as you would expect, a PDF generated by the DataMapper. A Resource PDF is a PDF from another source. For a DataMapper PDF, nothing else has to be done to set the background. For a PDF from another source, the Control Script should specify a path, for example:
Positioning the backgroundAfter that, the background can be positioned, setting the section's
For all possible positions, see MediaPosition. Setting a page range in scriptWhen a PDF that serves as a dynamic section background has multiple pages, you can specify a range of pages to be used, in a control script. The following script sets the page range from 2 to 5:
ExampleThis scripts sets a background on a Print section using absolute positioning.
