IMPB
IMPB is one of the barcode types that can be added to a template; see Barcode.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
Barcode properties
This topic lists the properties of the barcode type IMPB. For the properties of other barcode types, see Barcode type and properties.
Color
The Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker).
Output format
  • Defines how the barcode is output on the page. There are two possible formats:
    • SVG: Vector format. This is smaller in size, but not compatible with Email output.
    • PNG: Binary rasterized format. This is slightly larger than SVG but will display properly in Email output.
    • Last Topic Update: 04, January, 2017 02:54 AM
