UPC-A, UPC-E, EAN-8, EAN-13
UPC-A, UPC-E, EAN-8 and EAN-13 are a few of the barcode types that can be added to a template.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
Barcode properties
This topic lists the properties of the barcode types UPC-A, UPC-E, EAN-8 and EAN-13. For the properties of other barcode types, see Barcode type and properties.
Module width
Show guardbars
Checking this option adds guardbars to the barcode. Guardbars are bars at the start, in the middle and at the end that help the barcode scanner to scan the barcode correctly.
Scale
  • Proportionally: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Supplement
UPC-A, UPC-E, EAN-13, and EAN-8 may all include an additional barcode to the right of the main barcode.
  • Type: The supplement type can be 2-digit (originally used to indicate the edition of a magazine or periodical) or 5-digit (used to indicate the suggested retail price for books). In case this option is set to None, and the data includes digits for the 2 or 5 supplement, the supplement data will be skipped and the additional barcode will not be rendered.
    When the chosen supplement type doesn't match the data, the supplement data will be skipped and the additional barcode will not be rendered.
  • Height Factor: This is the relative height of the supplement's bars compared to the normal bars.
  • Space Before : Defines the space between the main symbol and the supplement, in cm.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
The Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker).
Output format
  • Defines how the barcode is output on the page. There are two possible formats:
    • SVG: Vector format. This is smaller in size, but not compatible with Email output.
    • PNG: Binary rasterized format. This is slightly larger than SVG but will display properly in Email output.
    • Last Topic Update: 04, January, 2017 02:58 AM
