openTextReader()Function that opens a file as a text file for reading purposes. The function returns a TextReader object. Please note that the temporary file must be closed at the end. openTextReader(filename,encoding)filename String that represents the name of the file to open. encoding String that specifies the encoding of the file to read (UTF-8, ISO-8859-1, etc.). ExampleIn the following example, the var fileIn = openTextReader(data.filename); |
