OpenTextWriter()This function opens a file as a text file for writing purposes. The function returns a TextWriter object. This must be closed at the end. OpenTextWriter(filename, encoding, append)filename String that represents the name of the file to open. encoding String specifying the encoding to use (UTF-8, ISO-8859-1, etc.).. append Boolean parameter that specifies whether the file pointer should initially be positioned at the end of the existing file (append mode) or at the beginning of the file (overwrite mode). ExampleIn the following example, the openTextWriter function is used to open the newly created temporary file for writing: var fileIn = openTextReader(data.filename); |
