extract()Extracts the text value from selected data: a node path, column, or rectangular region, depending on the type of data source. extract(left, right, verticalOffset, regionHeight, separator)Extracts a value from a position in a text file. Coordinates are expressed as characters (horizontally) or lines (vertically). left Number that represents the distance, measured in characters, from the left edge of the page to the left edge of the rectangular region. The leftmost character is character 1. right Number that represents the distance, measured in characters, from the left edge of the page to the right edge of the rectangular region. verticalOffset Number that represents the current vertical position, measured in lines. regionHeight Number that represents the total height of the region, measured in lines. separator String inserted between all lines returned from the region. If you don't want anything to be inserted between the lines, specify an empty string ("").
ExamplesExample 1:The script command
Example 2:The script command data.extract(1,22,9,6,"<br />"); means that the left position of the extracted information is located at 1, the right position at 22, the offset position is 9 (since the first line number is 10) and the regionHeight is 6 (6 lines are selected). Finally, the "<br/>" string is used for concatenation.
extract(xPath)Extracts the text value of the specified node in an XML file. xPath String that can be relative to the current location or absolute from the start of the record. ExampleThe script command data.extract('./CUSTOMER/FirstName'); means that the extraction is made on the FirstName node under Customer.
extract(columnName, rowOffset)Extracts the text value from the specified column and row. columnName String that represents the column name. rowOffset Number that represents the row index (zero-based), relative to the current position. To extract the current row, specify 0 as the rowOffset. Use ExampleThe script command data.extract('ID',0); means that the extraction is made on the ID column in the first row.
extract(left, right, verticalOffset, lineHeight, separator)Extracts the text value from a rectangular region in a PDF file. All coordinates are expressed in millimeters. left Double that represents the distance from the left edge of the page to the left edge of the rectangular region. right Double that represents the distance from the left edge of the page to the right edge of the rectangular region. verticalOffset Double that represents the distance from the current vertical position. lineHeight Double that represents the total height of the region. separator String inserted between all lines returned from the region. If you don't want anything to be inserted between the lines, specify an empty string (""). "<br/>" is a very handy string to use as a separator. When the extracted data is inserted in a Designer template, it will be interpreted as a line break, because <br/> is a line break in HTML and Designer templates are actually HTML files.
ExampleThe script command data.extract(4.572,51.815998,37.761333,3.7253342,"<br />"); means that the left position of the extracted information is located at 4.572mm, the right position at 51.815998mm, the vertical offset is 37.761333mm and the line height is 3.7253342mm. Finally, the "<br/>" string is used for concatenation.
