fieldExists()Method of the fieldExists(levelName, propertyName)This method returns true if the given metadata field exists at the given level in a PDF file. levelName String that specifies the metadata field. propertyName String that specifies the level. fieldExists(fieldName)This method returns true if the specified column exists in the current record in a CSV file. fieldName String that represents a field name (column) in a CSV file. fieldExists(xPath)This method returns true if the specified node exists in the current record in an XML file. xPath String that specifies a node. |
