findRegExp()Finds the first occurrence of a string that matches the given regular expression pattern, starting from the current position. findRegExp (regexpToFind, flags, leftConstraint, rightConstraint): rectValueText)Finds the first match for a given regular expression pattern starting from the current position. Regular expression flags (i,s,L,m,u,U,d) are specified in the flags parameter. The search can be constrained to a vertical column of characters located between the left and right constraint, each expressed in characters (in a text file) or millimeters (in a PDF file). The method returns Calling this method does not move the current position to the location where the match occurred. This allows you to use the method as a look-ahead function without disrupting the rest of the data mapping workflow.
regexpToFind Regular expression pattern to find. flags i: Enables case-insensitive matching. By default, case-insensitive matching assumes that only characters in the US-ASCII charset are being matched. Unicode-aware case-insensitive matching can be enabled by specifying the UNICODE_CASE flag (u) in conjunction with this flag. s: Enables dotall mode. In dotall mode, the expression . matches any character, including a line terminator. By default this expression does not match line terminators. L: Enables literal parsing of the pattern. When this flag is specified, then the input string that specifies the pattern is treated as a sequence of literal characters. Metacharacters or escape sequences in the input sequence will be given no special meaning. The CASE_INSENSITIVE (i) and UNICODE_CASE (u)flags retain their impact on matching when used in conjunction with this flag. The other flags become superfluous. m: Enables multiline mode. In multiline mode, the expressions ^ and $ match just after or just before, respectively, a line terminator or the end of the input sequence. By default, these expressions only match at the beginning and the end of the entire input sequence. u: Enables Unicode-aware case folding. When this flag is specified, then case-insensitive matching, when enabled by the CASE_INSENSITIVE flag (i), is done in a manner consistent with the Unicode Standard. By default, case-insensitive matching assumes that only characters in the US-ASCII charset are being matched. U: Enables the Unicode version of Predefined character classes and POSIX character classes. When this flag is specified, then the (US-ASCII only) Predefined character classes and POSIX character classes are in conformance with Unicode Technical Standard #18: Unicode Regular Expression Annex C: Compatibility Properties. d: Enables Unix lines mode. In this mode, only the '\n' line terminator is recognized in the behavior of ., ^, and $. leftConstraint Number indicating the left limit from which the search is performed. This is expressed in characters for a text file, or in millimeters for a PDF file. rightConstraint Number indicating the right limit to which the search is performed. This is expressed in characters for a text file, or in millimeters for a PDF file. Examples
or
Both expressions would match the following strings: 001-ABC, 678-xYz. Note how in the second version, where the regular expression is specified as a string, some characters have to be escaped with an additional backslash, which is standard in JavaScript. |
