moveToNext()Moves the position of the pointer in the source data file to the next line, row or node. The behavior and arguments are different for each emulation type: text, PDF, tabular (CSV), or XML. This is a method of the steps object (see steps). moveToNext(scope)Moves the current position in a text file or XML file to the next instance of Textscope Number that may be set to:
ExampleThe following line of code moves the current position to the next line that contains any text.
XMLscope Number that may be set to:
moveToNext(left, right)Moves the current position in a PDF file to the next line that contains any text, the search for text being contained within the left and right parameters, expressed in millimeters. left Double that represents the left edge (in millimeters) of the text to find. right Double that represents the right edge (in millimeters) of the text to find. moveToNext()Moves the current position in a CSV file to the next row, relative to the current position. |
