Attachments dialogThe Attachments dialog lets you add and remove static Email attachments. For more information about email attachments, see: Email attachments.
Select File dialogResources: lists the images that are present in the Images folder on the Resources pane. A preview of the selected image will be shown at the right. Disk: lets you select a file that resides in a folder on a hard drive that is accessible from your computer. If possible, a preview of the selected file will be shown.
Url: lets you select a file from a specific web address. Select the protocol and then enter the URL (for example, http://www.mysite.com/zipfiles/myfile.zip). If the selected file is an image, a preview will be shown below.
The option Save with template is available when choosing an image from disk or by URL. This inserts the image in the Images folder on the Resources pane. If not saved with the template, the image will remain external. External files need to be available when the template is merged with a record set to generate output, and their location should be accessible from the machine on which the template's output is produced. External files are updated (retrieved) at the time the output is generated.
