Font ManagerThe Fonts Manager contains the fonts that were added to the template manually. It essentially lists the fonts located in the Fonts folder of the Resources pane (see Fonts). Fonts with the same file name with a different extension are considered variations of the same font. For example, if there are three files, named gotham-book-webfont.eot, gotham-book-webfont.ttf, gotham-book-webfont.woff, only "gotham-book-webfont" appears in the Name column of this dialog. The following buttons appear to the right of the list of fonts:
Edit FontThe Edit Font dialog appears when clicking New or Edit from the Fonts Dialog.
