Line Chart Properties dialog
The Line Chart dialog appears when a Line Chart is right-clicked
and the Chart... option is clicked. It determines how the chart is
displayed when generating output and in Preview mode (see Business graphics).
General tab
Most settings on the General tab correspond to properties of the AmSerialChart class in the amCharts library; see: AmSerialChart.
- General Group:
- Display grid above graph:
Check to display the grid on top of the bars so that it is always
visible. (Equivalent to the
gridAboveGraphs property; see: gridAboveGraphs.)
- Rotate: Check to rotate
the chart 90 degrees so that the bars are horizontal starting
from the left. (Equivalent to the
rotate property; see: rotate.)
- Stack Series: Check to stack the values in one bar, instead of having one bar per value. (Equivalent to the
stackType property of the ValueAxis; see: stackType.)
- Text Group: Determines
how text is displayed in labels and legends.
- Font: Type in the font-face
to use to display text. The font must be installed on the system
and defaults to Verdana if the font is not found. (Equivalent to the
fontFamily property; see: fontFamily.)
- Size: Type in the size
of the font. Defaults to 11. (Equivalent to the
fontSize property; see: fontSize.)
- Color: Type in the
color in which to display text. The color value must be a valid
hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
color property; see: color.)
- 3D Group: Creates a 3D effect if both settings in this group are higher than 0.
- Depth: The depth of the 3D part of the plot area. (Equivalent to the
depth3D property; see: depth3D.) - Angle: The angle of the 3D part of the plot area. (Equivalent to the
angle property; see: angle.)
Value Axis tab
Settings on the Value Axis tab are equivalent to properties of the ValueAxis class in the amCharts library; see: ValueAxis.
- Title group:
- Label: Enter a label
for the value axis (the Y axis, or the X axis if the graph is rotated). (Equivalent to the
title property; see: title.)
- Bold: Check this option if the title should be bold. (Equivalent to the
titleBold property; see: titleBold.)
- Color: Enter a custom
color for the label (default is black). The color value must be
a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
titleColor property; see: titleColor.)
- Font Size: Enter a
font size for the label. (Equivalent to the
titleFontSize property; see: titleFontSize.)
- Grid group:
- Color: Enter a color
for the grid lines that divide the value axis. The color value
must be a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
gridColor property; see: gridColor.)
- Opacity: Enter the
opacity percentage of the grid. Default is 15%. 100 is fully opaque, 0 is transparent. (Equivalent to the
gridAlpha property; see: gridAlpha.)
- Thickness: Enter a
thickness for the grid lines. Default is 1. (Equivalent to the
gridThickness property; see: gridThickness.)
- Tick Length: Length of the tick marks. (Equivalent to the
tickLength property; see: tickLength.)
- Axis group:
for the value axis. The color value must be a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
axisColor property; see: axisColor.) - Opacity: Enter the
opacity in percentage for the axis. 100 is fully opaque, 0 is transparent. Set opacity to 0 to hide the axis. (Equivalent to the
axisAlpha property of the ValueAxis; see: axisAlpha.) - Thickness: Enter the
thickness of the axis. (Equivalent to the
axisThickness property of the ValueAxis; see: axisThickness.)
- Labels: Check this option to make the labels on the value axis visible. This is often useful in rotated charts. (Equivalent to the
labelsEnabled property of the ValueAxis; see: labelsEnabled.)- Frequency: Defines per how many grid lines a label will be placed. (Equivalent to the
labelFrequency property of the ValueAxis; see: labelFrequency.)
Category Axis tab
Settings on the Category Axis tab correspond to properties of the CategoryAxis class in the amCharts library; see: CategoryAxis.
- Title group:
for the category axis (the X axis, or the Y axis if the graph is rotated).(Equivalent to the
- Bold: Check if you
want the title to be bold. (Equivalent to the
color for the label (default is black). The color value must be a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
font size for the title. (Equivalent to the
- Grid group:
for the grid lines that divide the category axis. The color value must be a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
- Position: Specifies if a grid line is placed on the centre of a cell or on the beginning of a cell. (Equivalent to the
gridPosition property; see: gridPosition.) The position of the ticks (which is Middle by default) does not move with the grid. To change the tick position, add the following to the categoryAxis on the Source tab: "tickPosition": "start".
tickLength property; see: tickLength.)By default, one label per grid line will appear on the Category axis. To change that frequency, add the following to the categoryAxis section on the Source tab: "labelFrequency": "2" (replace 2 by the desired number of grid lines).
- Axis group:
axisAlpha property; see: axisAlpha.)
axisThickness property; see: axisThickness.)
- Auto Wrap: Specifies if axis labels (when horizontal) should be wrapped if they don't fit in the allocated space. (Equivalent to the
autoWrap property; see: autoWrap.)
Graphs
Settings on the Graphs tab correspond to properties of the AmGraph class in the amCharts library; see: AmGraph.
- Line:
- Thickness: Sets the thickness of the lines in a Line chart. (Equivalent to the
lineThickness property; see: lineThickness.)
Set "fillAlphas" = 1 on the Source tab to color the space below the lines.
Legend tab
Settings on the Legend tab correspond to properties of the AmLegend class in the amCharts library; see: AmLegend.
- Show Legend: Specifies if legend is enabled or not. (Equivalent to the
enabled property; see: enabled.)
- Legend Group: Defines how
the legends are shown.
- Equal label widths:
Check so that all labels are of equal width in the Legends box.
The Legend's width will accommodate the largest value. (Equivalent to the
equalWidths property; see: equalWidths.) - Position: Use the drop-down
to select where the legend is shown: at the Right, Left, Top or Bottom. (Equivalent to the
position property; see: position.) - Align: Use the drop-down
to select how to align the text in the labels: Left, Middle or
Right.(Equivalent to the
align property; see: align.) - Horizontal Space: Horizontal space between legend items, in pixels. (Equivalent to the
spacing property; see: spacing.) - Vertical Space: Enter
a numerical value (in pixels) to define the vertical space between legend items, and also between the legend border and the first and last legend item. (Equivalent to the
verticalGap property; see: verticalGap.) - Max Columns: Enter
a numerical value to define the maximum number of columns in the legend. If the Legend's position is set to "right" or "left", this is automatically set to 1. (Equivalent to the
maxColumns property; see: maxColumns.)
- Values Group: Defines if
and how values are shown in the Legend.
- Text: Enter the text
used to display the values. Variables display specific
data, <br> can be used to create a new line:
- [[percents]] : Contains the percentage of the chart the
value represents.
- [[value]] : Contains the numerical value of the field.
- Any Text: Adding text (such as a dollar sign or column,
etc) will make it appear in each label.
(Equivalent to the valueText property; see: valueText.)
- Markers Group: Defines
how the Legend's Markers look. Markers are icons with a color matching the
Legend with its corresponding line.
- Type: Use the drop-down
to select in which shape the Markers are displayed; "none"
hides the Markers completely. (Equivalent to the
markerType property; see: markerType.) - Size: Enter the size
(in pixels) for the Markers to be displayed. (Equivalent to the
markerSize property; see: markerSize.) - Label Gap: Enter the
distance (in pixels) between the legend marker and legend text. (Equivalent to the
markerLabelGap property; see: markerLabelGap.) - Border Width: Use the
drop-down to define the thickness of the border added to the Markers.
The default value (0) means the line will be a "hairline" (1 px). In case the Marker type is line, this style will be used for the line thickness. (Equivalent to the
markerBorderThickness property; see: markerBorderThickness.) - Border Color: Color of the Legend's border. The value must be a valid hexademical color (HTML Hex Color) or a predefined CSS color (CSS color names). (Equivalent to the
markerBorderColor property; see: markerBorderColor.) - Border Opacity: Enter
a numerical value between 0 and 100 to define the opacity (in
percentage) of the border. (Equivalent to the
markerBorderAlpha property; see: markerBorderAlpha. When specified on the Source tab, the value should be between 0 and 1, e.g. 0.8.)
Source tab
The JSON on the Source tab reflects the choices made in the other tabs and, more importantly, provides the possibility to add in any amCharts configuration option that is unavailable via the other tab menus. For more information see: Adding and editing properties manually.
