Section properties dialogsThe respective section properties dialogs are opened via the contextual menu:
Email section propertiesFor information about Email sections, see: Email templates. Properties tabThe properties for an Email section are minimal and contain the following options:
Includes tabThis tab lists the style sheets that can be applied to the email section when producing the output. Style sheets are loaded in the order shown, and styles in later style sheets overwrite earlier ones when the same selector is used. (See Includes dialog and Styling templates with CSS files.) Attachments tabThe Attachments tab lets you select files and delete attachments. For more information, see: Email attachments. Print section propertiesFor information about Print sections, see: Print sections. Properties
For an explanation of other settings on the Properties tab, see Page settings: size, margins and bleed. Includes TabThe Includes tab defines which style sheets and JavaScript files should be applied to the section when generating output, and in which order; see Includes dialog. Finishing tabThis tab defines finishing options for this section when it is printed. For an explanation of all Binding and Hole making options, see Finishing Options. Sheet Configuration tabThe Sheet Configuration tab defines how different Print context sections output on different Media (see Media) and using different Master Pages (see Master Pages). For an explanation of all settings on this tab, see Sheet Configuration dialog. Background tabThis tab defines the background of the current Print section; see Using a PDF file as background image. Numbering tabThe Numbering tab defines how page numbers are configured in the current Print section; see Configuring page numbers. Web Section PropertiesThe Web section properties define some of the web page properties,
especially details appearing in the header. Properties tabFor information about the settings on the Properties tab, see Setting the title, meta data and a shortcut icon. Includes TabThe Includes tab defines which style sheets and JavaScript files should be included in the section when generating output, and in which order; see Includes dialog. Arrange SectionsThe Arrange dialog is used to change the order of sections within a
context. This can have an effect on how they are outputted; see: Print sections, Email templates To access the Arrange dialog, on the Resources pane, right-click on any section or the context containing them, and click Arrange.
