US Postal Service IMPB Settings
US Postal Service Intelligent Mail Package Barcodes (IMPB) are used by the United States postal service for parcel deliveries. They contain parcel destination information along with other information about the delivery.
To create dynamic barcodes, Metadata options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode. Use the following options to configure the output Barcode settings:
- General group:
- Include in output check box: This determines whether of not this Additional Content entry should be included in the output or not.
It is checked by default for all new entries. This option allow for "libraries" of Additional Content to be created in Presets. Libraries from which you can pick and choose what entries you wish to have included, at time of printing.
- Description edit box: An edit box for adding an optional Description to the Additional Content entry.
- Position group:
- USPS IMPB Properties group:
- Barcode height: The height of the bars in the barcode, in inches (in). Value must be between 0.075 and 1.0 inches.
- Module width: The thickness of thin bars in the barcode, in inches (in). Thicker bars are a multiple of this value. Value must be between 0.013 and 0.021 inches.
- Text to barcode clearance: The space between the barcode bars and the top and bottom text, in inches (in). Value must be between 0.125 and 0.25 inches.
- Text height: The height of the text, in inches (in). Value must be between 0.09 and 0.125 inches.
- Line to text clearance: The space between the guard lines and text, in inches (in). Value must be between 0.031 and 0.04 inches.
- Guard bar height: The thickness of the guard lines, in inches (in). Value must be between 0.031 and 0.063 inches.
- Text: Enter the text used to generate the Barcode.
Add button: Click to display a list of variable data that could be used for generating the Barcode. This includes metadata fields which must previously have been added in the Metadata Options (likely at the Document Tags level), as well as some information fields.
- Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see the How to Set Conditionals page.
