Dynamic Custom Element Editor DialogUse this dialog to create Rules for determining whether a Custom setting in the Dynamic PPD Options page of the Printer Wizard should be applied or not. The Dynamic Custom Element Editor dialog is basically a logical Rule creation dialog. It can be broken up as follows: Rule nameEither enter or update the Custom Rule name here. GroupA Group consists of one or more sub-Group, Size, Position or Metadata rules with a logic operator.
The top level is always a Group. A Group can contain one or more sub-Groups. RuleA Rule is a logic expression using a single operator or function, and their associated operand(s). The number and type of operands is dependent upon the operator or function chosen. The Rule types are as follows:
Expand buttonTo allow logical constructs than are not currently catered for by the Dynamic Custom Element Editor, the Expand button is available at any time. An example of where this might be useful is in converting a text comparison to a case insensitive comparison. To do so, click the Expand button to convert the rule into JavaScript, then add The Expansion is a one-way translation that cannot be undone. Once expanded, the rule stays expanded. The only way to go back to the previously configured rule(s), is to Cancel the Rule editor dialog.
