Printer Settings
The Printer Settings page provides options for cut-sheet printers. It maps types to printer trays. It is available for AFP, IPDS, PCL and PostScript printers that are configured for cut-sheet printing.
- Map media by options: Select from following choices:
- Media Attribute displays all Media details, except the Tray selection.
- Tray displays just the Media name and Tray selections.
- Both displays all Media details.
- Media/Tray Table columns:
- Media: Lists the
Media name, as defined in the template.
- Tray: Use the drop-down
to select in which Tray to send any page using the media.
- Position: Enter
a MediaPosition option on the printer to define the media
to use.
- Weight: Enter a
weight for the paper.
- Type: Use the drop-down
to select which type of stock to use on the printer.
- Color: Use the
drop-down to select which color the paper should be on the
printer.
- Media/Tray Table buttons:
Add: Adds a new Media/Tray entry in the table.
Delete: Deletes the current Media/Tray selections from the table.
/ Move Up / Move Down: Move the selected Media/Tray entries up or down within the table.
Import Tray Settings: Import the Media/Tray settings from a Connect Template. The options are to:- Import from current template, which will import any Media/Tray settings from the current Connect Template into the table.
- Import from template file, which allows you to browse for a Connect Template to import the Media/Trays settings from.
There is no restriction on how many Templates you may import settings from.
