Aztec CodeAztec is one of the types of barcodes that can be added to a template; see Barcode. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the barcode type Aztec. For the properties of other barcode types, see Barcode type and properties. Module sizeEnter the size of the square modules in pixels Configuration typeUse the drop-down to select the format type used when creating the barcode: only full range format, only compact formats, or any format. Preferred configurationUse the drop-down to select the preferred format for the barcode. Note that the barcode generator may choose a different format if the data cannot be represented by the preferred format. EncodingUse the drop-down to select the encoding type:
Error Correction LevelThis option reserves a percentage of the symbol capacity for error correction. The recommended percentage for this type of barcode is 23. RuneWhen set to a value between 0 and 255, an Aztec Rune corresponding to the selected value is created. Set the Rune to -1 to disable this feature. ScaleDefines if and how the rendered barcode is scaled in relation to the parent element:
ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). Output format
