CodabarCodabar is one of the barcode types that can be added to a template. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the Codabar barcode. For the properties of other barcode types, see Barcode type and properties. Module widthSpecifies the width of the narrow bars in centimeters. Changing this value to a higher value will make the barcode bigger when Scale is set to None. Start Char and Stop CharUse the drop-down to select the start and stop character for the barcode, which defines the encoding mode. Available characters are A, B, C. ScaleDefines if and how the rendered barcode is scaled in relation to the parent element:
Add ChecksumWhen checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated. Human Readable MessageWhen this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt). ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). Output format
