Data MatrixData Matrix is one of the types of barcodes that can be added to a template; see Barcode. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the QR barcode. For the properties of other barcode types, see Barcode type and properties. Hex InputFor optimized mailings, German Post requires the supplied data for the Data Matrix barcode to be hexadecimal input. Dots Per PixelsType the number of dots per pixel. To optimize barcode quality a Data Matrix symbol should not be printed with dots smaller than 4 pixels. EncodingThe data represented in the symbol can be compressed using of the following algorithms.
Preferred formatUse the drop-down to select the size of the Data Matrix. ScaleDefines if and how the rendered barcode is scaled in relation to the parent element:
ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). Output format
