MaxiCodeMaxiCode is one of the barcode types that can be added to a template; see Barcode. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the MaxiCode barcode. For the properties of other barcode types, see Barcode type and properties. ResolutionSelect the printer output definition for the barcode (200, 300, 400, 500 or 600 dpi). ModePlanetPress Connect supports several modes; for an explanation of these modes see the MaxiCode page on Wikipedia. ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). |
