OneCode, KIX Code, Royal Mail, Australia PostOneCode, KIX Code, Royal Mail and Australia Post are some of the types of barcodes that can be added to a template; see Barcode. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the barcode types OneCode, KIX Code, Royal Mail and Australia Post. For the properties of other barcode types, see Barcode type and properties. Height, width and spacingThe height, width and spacing of the barcode are all measured in pixels (38 dpi).
ScaleDefines if and how the rendered barcode is scaled in relation to the parent element:
ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). Output format
