PDF417PDF417 is one of the types of barcodes that can be added to a template; see Barcode. The barcode can be added either using the Barcode toolbar button or through selecting Insert > Barcode on the menu; see Adding a Barcode. Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu. Barcode propertiesThis topic lists the properties of the barcode type PDF417. For the properties of other barcode types, see Barcode type and properties. ModeUse the drop-down to set the compaction mode:
Error Correction LevelUse the drop-down to select the built-in error correction method based on Reed-Solomon algorithms. The error correction level is adjustable between level 0 (just error detection) and level 8 (maximum error correction). Recommended error correction levels are between level 2 and 5, but the optimal value depends on the amount of data, printing quality of the PDF417 symbol and decoding capabilities of the scanner. Nr. of ColumnsThe number of data columns can vary from 3 to 30. Nr. of RowsA PDF417 bar code can have anywhere from 3 to 90 rows. Bar heightDefines the height of the bars for a single row measured in pixels drawn. CompactCheck this option to use Compact PDF417 instead of the PDF417 barcode. This shortened form of the PDF417 barcode is useful where the space for the symbol is restricted. ScaleDefines if and how the rendered barcode is scaled in relation to the parent element:
ColorThe Color property allows you to choose a different Barcode color (instead of black) and Background color (instead of white), by typing a hexadecimal color value (see for example w3school's color picker). Output format
