Send to Workflow dialog
The Send to Workflow dialog sends selected templates, data mapping configurations and print presets to the PlanetPress Workflow server.
Configurations: Initially this list contains the Connect files that are currently open.
- Browse: This button opens the Select Files dialog that lets you add one or more templates, data mapping configurations and print presets to the list.
- Select Preset: Opens the Select Preset dialog, which lists all Print Presets found in the folder:
<root>\Users\<username>\Connect\workspace\configurations. You can select one or more Print Presets to add them to the list of configurations in the Send to Workflow dialog. - Delete: Deletes the selected file from the list of files to send.
- Workflow Server: Use the drop-down to select where to send the files. This lists all the detected PlanetPress Workflow installations detected on the network.
- Send: Sends all selected Connect files to the selected Workflow Server. You can use the topmost checkbox to select all of the listed files at once.
- Cancel: Click this button to close the dialog without sending files to Workflow.
