Control Script: Setting a Print section's background
In the Print context, a PDF file can be used as a Print section's background. To learn how to do this without a Control Script, see Using a PDF file as background image.
With a Control Script, a Print section's background can be set dynamically. You could for example specify a particular PDF file as a section's background depending on the value of a field in the current record. This topic shows how.
Setting a background in script
The Control Script should first enable a background on the section, in case an initial background wasn't set via the user interface. This is done by setting the source type for the background of the section to
merge.template.contexts.PRINT.sections['Policy'].background.source = BackgroundResource.RESOURCE_PDF;
var resourceUrl = 'images/policy-' + record.fields.policy + '.pdf';
merge.template.contexts.PRINT.sections['Policy'].background.url = resourceUrl;
Positioning, scaling and rotating the background
After a background has been selected, it can be positioned, scaled and rotated, using properties of the background object; see background.
To position the background, for example, set the section's background.position:
activeSection.background.position = MediaPosition.FIT_TO_MEDIA;
For all possible positions, see MediaPosition.
Setting a page range in script
When a PDF that serves as a dynamic section background has multiple pages, you can specify a range of pages to be used, in a control script.
Put the number of the first page in the range in the section's background.start field and the last page in background.end.
This requires you to set the background.allPages option to false, first. This option takes precedence, so when it is true, the entire PDF will be used, even if a page range has been set.
The following script sets the page range from 2 to 5:
merge.template.contexts.PRINT.sections['Policy'].background.allPages = false;
merge.template.contexts.PRINT.sections['Policy'].background.start = 2;
merge.template.contexts.PRINT.sections['Policy'].background.end = 5;
resource() function to check the number of pages or for example the page height and width before setting it as a background (see resource()).Example
This scripts sets a background on a Print section using absolute positioning.
var activeSection = merge.template.contexts.PRINT.sections['Section 1'];
activeSection.background.source = BackgroundResource.RESOURCE_PDF;
activeSection.background.url = "images/somepage.pdf";
activeSection.background.position = MediaPosition.ABSOLUTE;
activeSection.background.left = "10mm";
activeSection.background.top = "10mm";
