Data Matrix
Data Matrix is one of the types of barcodes that can be added to a template; see Barcode.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
Barcode properties
This topic lists the properties of the Data Matrix barcode. For the properties of other barcode types, see Barcode type and properties.
replace() call in the Barcode script, after expanding the script.Hex Input
For optimized mailings, German Post requires the supplied data for the Data Matrix barcode to be hexadecimal input.
Check this option if your input data is a hexadecimal code. The incoming data will be interpreted as hexadecimal input and decoded to ASCII before passing the string to the Barcode library.
Dots Per Pixels
Type the number of dots per pixel. To optimize barcode quality a Data Matrix symbol should not be printed with dots smaller than 4 pixels.
Encoding
The data represented in the symbol can be compressed using of the following algorithms.
ASCII is used to encode data that mainly contains ascii characters (0-127)
C40 is used to encode data that mainly contains numbers and uppercase characters.
Text is used to encode data that mainly contains numbers and lowercase
Base256 is used to encode 8 bit values
Auto Detect automatically detects the data content and encodes using the most appropriate method.
None does not use any encoding.
Preferred format
Use the drop-down to select the size of the Data Matrix.
Scale
- None: The barcode is rendered based on the module width.
- Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Color
Output format
SVG: Vector format. This is smaller in size, but not compatible with Email output.
PNG: Binary rasterized format. This is slightly larger than SVG but will display properly in Email output.
