Network Considerations
The following should be taken into consideration in regards to network settings and communications
  • If a local proxy is configured (in the Internet Explorer Options dialog), the option Bypass proxy server for local addresses must be checked, or some features depending on local communication will not work.
Firewall/Port considerations
For Firewall/Port considerations, please see this article in the Knowledge Base: Connect Firewall/Port Configuration
