Send to Workflow dialog
The Send to Workflow dialog sends selected templates, data mapping configurations and Print Presets to the PlanetPress Workflow server.
Configurations: Initially this list contains the Connect template and data mapping configuration that are currently open, and the Job Creation Preset and Output Creation Preset that were last modified.
- Browse: This button opens the Select Files dialog that lets you add one or more templates, data mapping configurations and Print Presets to the list.
- Select Preset: Opens the Select Preset dialog. This dialog lists all Print Presets found in the folder:
<root>\Users\<username>\Connect\workspace\configurations. There are two ways to make it easier to find the file that you need:- The Show drop-down list lets you select the type of preset that you want to open.
- In the Filter field, you can enter (part of) a preset name to filter the list for matching presets.
- Delete: Deletes the selected file from the list of files to send.
- Workflow Server: Use the drop-down to select where to send the files. This lists all the detected PlanetPress Workflow installations detected on the network.
- Send: Sends all selected Connect files to the selected Workflow Server. You can use the topmost checkbox to select all of the listed files at once.
- Cancel: Click this button to close the dialog without sending files to Workflow.
