Network Considerations
The following should be taken into consideration in regards to network settings and communications
- If a local proxy is configured (in the Internet Explorer Options dialog), the option Bypass proxy server for local addresses must be checked, or some features depending on local communication will not work.
Firewall/Port considerations
The following describes all of the ports that can be used by an OL Connect solution. IT staff may decide the firewall strategy to follow for their internal requirements and needs depending on the statements outlined herein.
| Listens on port # | Destination port # | Type | Comment | |
| Messenger | 5863/5864 | 5863/5864 | TCP+UDP | Used for inter-module communication |
| Connect Server | 9340 | TCP | Used for Connect REST API | |
| Connect Server | 9350 | TCP | Dedicated internal connection for inter-process communication (i.e. between engines) | |
| HTTP Server | 8080 | TCP | ||
| HTTPS Server | 443 | TCP | ||
| NodeJS Server | 9090 | TCP | ||
| NodeJS HTTPS Server | 8443 | TCP | ||
| SMTP Input plugin | 25, or 587 when encryption is enabled | TCP | ||
| Email Input plugin | 110 | TCP | Default POP3 port | |
| Secure Email Input plugin | 993 | TCP | ||
| Send Email plugin | 25 | TCP | Default SMTP port | |
| Secure Email Output plugin | 587 | TCP | ||
| LPR | 515 | TCP | ||
| LPD | 515 | TCP | ||
| Telnet | 9100 | TCP | ||
| FTP Input/Output | 21 | TCP | ||
| MySQL | 3306 | TCP+UDP | ||
| Microsoft SQL Server | 1433 | TCP+UDP | ||
| HyperSQL | 9001 | TCP |
- Port numbers in bold type are user configurable.
- Port numbers in bold underlined type are based on the type of database used.
- Some of the ports listed above may also be used by other modules.
- User-configurable modules may use other ports entirely, depending on the settings defined by the end user. A few examples:
The Create Email Content plugin will use the port defined in the Mail host setting in Workflow (see OL Connect Preferences).
The ports used by the HTTP Client Input task, Legacy SOAP Client and SOAP Client plugin depend on the configured URL.
