PDF Attachments dialog
The PDF Attachments dialog defines options for the Email context that are used when generating email output with PDF attachments (see Generating Email output).
To open this dialog, right-click the Email context on the Resources pane and select PDF attachments.
Alternatively, select Context > PDF Attachments on the main menu. This option is only available when an Email section is being edited in the Workspace.
- Print Context Image Compression: Defines the properties of the PDF when attaching the Print context to email output.
 - Lossless: Enables maximum quality in the PDF. Note that this will produce a larger PDF.
 - Quality: Disabled when Lossless is checked. Determines the quality (aka compression) of the attached PDF.
 - Tile Size: Use the drop-down to select the size of the tiles used in the image. When low Quality values are used to optimize images smaller than 1024 x 1024 pixels, using the largest tile size will produce better results.
