Codabar Settings
Codabar barcodes support the following data: 0-9 - $ : / . + plus the optional specification of start/stop characters.
To create dynamic barcodes, Metadata options must first have been set (see Meta Data options).
General group:
Position group:
If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
- Codabar Properties group:
 - Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
 - Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
 - Bar width ratio: Set the Barcode bar width.
 - Default start symbol: Use the drop-down to select the optional Barcode start character, which defines the encoding mode.
 - Default stop symbol: Use the drop-down to select the Barcode stop character, which defines the encoding mode.
Print human readable text: Check to add a textual version of the Barcode data.
Vertically-oriented fonts (fonts whose typeface name begin with the at (@) character) are not supported in Connect.
 - Display start/stop symbols checkbox: Adds the stop/start symbols to the Barcode text.
- Process Tilde:
