Interleaved 2 of 5 Settings
Interleaved 2 of 5 barcodes are also known as "ITF" and "2/5 Interleaved". It is a numeric only barcode whose data must contain an even number of digits, as the barcode uses sequences of two digits interleaved with each other to create a single symbol. If the numeric data contains an odd number of digits, then a leading zero must be added to the beginning of the data.
General group:
Position group:
If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
Interleaved 2 of 5 Properties group:
Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
Bar width ratio: Set the Barcode bar width.
Print human readable text: Check to add a textual version of the Barcode data.
Vertically-oriented fonts (fonts whose typeface name begin with the at (@) character) are not supported in Connect.
- Process Tilde:
