UPC-E Settings
The Universal Product Code (UPC-E) Barcode is widely used for tracking trade items in stores and at the point-of-sale. It consists of 6 numerical digits which are uniquely assigned to each trade item.
To create dynamic barcodes, Metadata options must first have been set (see Meta Data options).
General group:
Position group:
If Imposition options such as auto-positioning and scaling were selected, these options won't apply to the Additional Content added to the physical N-Up sheet.
UPC A Properties group:
- Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
 - Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
Checksum: Use the drop-down to select how to deal with the Barcode checksum:
Ignore: Ignore checksum calculations.
Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
Check: Verify the Barcode has a valid checksum.
Add: Calculate and add a checksum character to Barcode, regardless of current value.
Print human readable text: Check to add a textual version of the Barcode data.
Vertically-oriented fonts (fonts whose typeface name begin with the at (@) character) are not supported in Connect.
- Process Tilde:
