MSI
MSI is one of the types of barcodes that can be added to a template; see Barcode.
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Barcode properties
This topic lists the properties of the barcode type MSI. For the properties of other barcode types, see Barcode type and properties.
Module width
Scale
- None: The barcode is rendered based on the module width.
 - Fit to box: The barcode is stretched to fit the parent box in both width and height.
Add Checksum
When checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Checksum Type
The Checksum type can be MSI10, MSI11, MSI1010 or MSI1110; see https://en.wikipedia.org/wiki/MSI_Barcode.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
- SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
 - PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
