POSTNET
POSTNET is one of the barcode types that can be added to a template; see Barcode.
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Barcode properties
This topic lists the properties of the barcode type POSTNET. For the properties of other barcode types, see Barcode type and properties.
Module width
Bar height
You can set the height (in cm) of the short bars and the tall bars in the Postnet barcode.
Scale
Fit to box: The barcode is stretched to fit the parent box in both width and height.
Proportionally: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
- SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
 - PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
