USPS IMpb
USPS IMpb is one of the barcode types that can be added to a template; see Barcode.
In PlanetPress Connect versions prior to 2019.2 this barcode was called "IMPB".
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Barcode properties
This topic lists the properties of the USPS IMpb barcode type. For the properties of other barcode types, see Barcode type and properties.
Color
Output format
- SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
 - PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
