Installation prerequisites
  • Make sure your system meets the System requirements.
  • PlanetPress Connect Version 2020.1 can be installed under a regular user account with Administrator privileges., see User accounts and security.
  • PlanetPress Connect must be installed on an NTFS file system.
  • PlanetPress Connect requires Microsoft .NET Framework 4.5 already be installed on the target system.
  • Connect 2019.1 requires updated Connect License and/or Update Client.
    See Upgrading from previous Connect versions for details.
  • In order to use the automation features in Version 2020.1, PlanetPress Workflow 2020.1 will need to be installed.
    This can be installed on the same machine as an existing PlanetPressĀ® Suite 7.x installation or on a new computer.
    For more information, please see Information about PlanetPress Workflow.
    If Workflow installation finds that .NET 4.0 is not already installed, it will install that version as part of the setup process.
    If LaserFiche or the ICR libraries are chosen as part of the Workflow installation, then .NET 3.5 must also be installed. This will need to be installed manually, as .NET 3.5 is not included in the Workflow setup.
