Properties and runtime parameters
A data mapping configuration's properties hold data that can be used throughout the data mapping workflow to compare against in conditions or to complement the existing data.
A number of properties are predefined, such as the path of the file that is currently being processed, and the current position of the pointer in the data.
It is also possible to define custom properties. For instance, a unique ID could be created to be added to each record in the output for integrity checks later on, or a time stamp could be added to create reports. A tag could be added to process certain records differently.
Ultimately data mapping configurations are meant to be used in OL Connect Workflow processes, to extract data from a particular type of data file.
Runtime parameters are properties that will pass variables from OL Connect Workflow to the data mapping configuration.
Certain runtime parameters are predefined, such as the ones that refer to the JobInfo variables in Workflow. For an overview see Fixed automation properties.
You can also define custom runtime parameters. With those, you could, for example:
- Pass a JSON structure, containing boundary information as well as the name and location of fields to be extracted dynamically from a data stream. This way, a generic data mapping configuration could be used to process several kinds of different files.
- Define default values that are different from one data mapping instance to the next, even when using the same data mapping configuration.
Defining custom properties and runtime parameters
You can define custom properties and runtime parameters under Properties in the Preprocessor step (see Preprocessor step properties).
To add a property:
- Select the Preprocessor step on the Steps pane.
- On the Step properties pane, under Properties, click the Add button
. See Properties for an explanation of the settings for properties.
Accessing properties and runtime parameters
There are different ways to access properties and runtime parameters in a data mapping workflow.
- Property-based fields. A property-based field is filled with the value of a property. See Property-based field.
- Step settings. Properties can be selected in the Condition, Multiple Conditions and Repeat step properties (see Condition step, Multiple Conditions step and Repeat step).
- Script.
Scripts can access properties through the DataMapper Scripts API. (See also: Using scripts in the DataMapper.)
- The
sourceRecordobject has apropertiesarray that lets you access custom properties that are added to each individual record, i.e. the scope of the property is set to Each record. (See: sourceRecord.)
To change the value of such a property you could use an Action step (see Action step). Note that the property's value will be reset at the beginning of each source record. - The
dataobject has apropertiesarray that lets you access custom properties that are added to the data as a whole, i.e. the scope of the property is set to Entire data. (See: data.) These are read-only. - To access a runtime parameter inside of any JavaScript code within the data mapping configuration, use
automation.parameters.runtimeparametername. (See: automation.) Runtime parameters are read-only.
- The
